[gdal-dev] Which Proj.4 transforms are available in GDAL?
Joaquim Luis jluis at ualg.pt
Sat Aug 26 16:02:35 PDT 2017
>> gdaltransform -s_srs EPSG:4326 -t_srs +proj=bonne
>> ERROR 6: Failed to initialize PROJ.4 with `+proj=bonne +lon_0=0 +lat_1=0
>> +x_0=0 +y_0=0 +ellps=WGS84 +units=m +no_defs'.
> I thing the issue is that lat_1=0 is invalid for bonne. Any non zero
> value is OK
Sorry Even, but it still fails
gdaltransform -s_srs EPSG:4326 -t_srs "+proj=bonne +lat_0=1 +wktext"
ERROR 6: Failed to initialize PROJ.4 with `+proj=bonne +lat_0=1 +wktext'.
And I'm facing some other issues with the +wktext.
This GMT using proj.4 via GDAL, and it works.
grdproject lixo.grd -J+proj=sinu -Glixo2.grd
but adding +wktext makes it fail in GDAL
grdproject lixo.grd -J"+proj=sinu +wktext" -Glixo2.grd
ERROR 6: Failed to initialize PROJ.4 with `+proj=sinu +wktext'
