[gdal-dev] vrt: prevent opening all source files on open?
Vincent Schut schut at satelligence.com
Mon Aug 28 05:48:39 PDT 2017
On 08/28/2017 01:51 PM, Even Rouault wrote:
> On lundi 28 août 2017 13:36:36 CEST Vincent Schut wrote:
> > On 08/28/2017 12:30 PM, Even Rouault wrote:
> > > Vincent,
> > > http://gdal.org/gdal_vrttut.html should help:
> > > """Some characteristics of the source band can be specified in the
> > > optional SourceProperties tag to enable the VRT driver to differ the
> > > opening of the source dataset until it really needs to read data from
> > > it. This is particularly useful when building VRTs with a big number
> > > of source datasets. The needed parameters are the raster dimensions,
> > > the size of the blocks and the data type. If the SourceProperties tag
> > > is not present, the source dataset will be opened at the same time as
> > > the VRT itself.
> > > <SimpleSource>
> > > <SourceFilename relativeToVRT="1">utm.tif</SourceFilename>
> > > <SourceBand>1</SourceBand>
> > > <SourceProperties RasterXSize="512" RasterYSize="512" DataType="Byte"
> > > BlockXSize="128" BlockYSize="128"/>
> > > <SrcRect xOff="0" yOff="0" xSize="512" ySize="512"/>
> > > <DstRect xOff="0" yOff="0" xSize="512" ySize="512"/>
> > > </SimpleSource>
> > > Note: in theory, the VRT driver could be improved to implement this
> > > lazy opening behaviour without requiring SourceProperties, but
> > > until/if this is implemented some day, you have to use
> SourceProperties.
> > > Even
> > Unfortunately, it's more complex. Both vrt's have SourceProperties tags
> > for each source.
> > I did another experiment to test if it is .hgt versus .tif, and it
> > appears to be something else: I removed all but one of the ComplexSource
> > items from each. Now both of them appear to try to open the source
> raster.
> > The vrt which apparently does not open it's sources is this one:
> https://cloud.sdsc.edu/v1/AUTH_opentopography/Raster/SRTM_GL1/SRTM_GL1_srtm.
> > vrt Even opening that with /vsicurl/ is fast.
> > Copying this vrt locally (and thus invalidating the source paths) works
> > and does not result in a read error. Remove all but one of the
> > ComplexSource elements, and I get an error on running gdalinfo on it
> > (because it cannot find the source raster). I'm stumped...
> > sorry, have to go to a meeting now. More later.
> Oh I see. There are particular code paths in the case where we have a
> VRT made of a single source for optimization. For example for doing
> multi-band at once RasterIO operations. Or GetOverviewCount() will
> call the source GetOverviewCount() to expose them at the VRT level.
> Normally only GDALOpen() on such VRT shouldn't cause the source to be
> opened. So I'd suspect you've a call to GetOverviewCount()
> A way of workarounding this is to add a fake source such as
> <ComplexSource>
> <SourceFilename>/dev/null</SourceFilename>
> <SourceProperties RasterXSize="1" RasterYSize="1" DataType="Byte"
> BlockXSize="1" BlockYSize="1" />
> <SrcRect xOff="0" yOff="0" xSize="0" ySize="0" />
> <DstRect xOff="0" yOff="0" xSize="0" ySize="0" />
> </ComplexSource>
Ah, thanks Even, that works!
> > thanks!
> > Vincent.
> > > > Hi,
> > > > Is there a way (or: what are the prerequisites) to avoid gdal
> opening
> > > > all source files from a vrt on opening the vrt?
> > > > Context: I have created a large vrt, referencing many tif files.
> Both
> > > > the vrt and tifs are remote (using /vsigs/). It works, but
> opening (e.g.
> > > > running gdalinfo) is very slow.
> > > > I have a comparable vrt where the main difference is that it
> references
> > > > .hgt files instead of tifs. Running gdalinfo on this vrt is almost
> > > > instantaneous.
> > > > As there are no other significant differences otherwise, I wonder if
> > > > this is because if the vrt machinery encounters a tif, it starts to
> > > > check if there are any accompanying overviews (or other important
> > > > metadata), while it does not do that for a .hgt file? Or is there a
> > > > different reason? And how can I prevent this (without, preferably,
> > > > changing to a different source file format)?
> > > > Thanks,
> > > > Vincent.
> > > > _______________________________________________
> > > > gdal-dev mailing list
> > > > gdal-dev at lists.osgeo.org
> > > > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170828/51d2c620/attachment-0001.html>
