[gdal-dev] Which Proj.4 transforms are available in GDAL?
    Joaquim Luis
    jluis at ualg.pt
    Mon Aug 28 09:25:55 PDT 2017
>>> gdaltransform -s_srs EPSG:4326 -t_srs "+proj=bonne +lat_0=1 +wktext"
>> ERROR 6: Failed to initialize PROJ.4 with `+proj=bonne +lat_0=1
>> +wktext'.
> It is lat_1 which must be non zero.
>> grdproject lixo.grd -J"+proj=sinu +wktext" -Glixo2.grd
>> ERROR 6: Failed to initialize PROJ.4 with `+proj=sinu +wktext'
> Perhaps due to the lack of datum/ellipsoid, if you don't have a
> proj_def.dat file that will contain the implicit one
Thanks. That was the case(s)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170828/a4310b2c/attachment.html>
