[gdal-dev] Fwd: [OpenJPEG] OpenJPEG 2.2.0 is out ! Faster and safer.
Even Rouault even.rouault at spatialys.com
Mon Aug 28 11:55:59 PDT 2017
On lundi 28 août 2017 18:00:03 CEST N. Farah wrote:
> Thanks Even for the quick response. I'll give it a try with setting
> OPJ_NUM_THREADS env variable to 8. Does it need to be used with
> GDAL_NUM_THREADS ? Any url to read about those two env variables ?
I've added some documentation per
https://trac.osgeo.org/gdal/changeset/39954
> The two dataset i used:
> <http://data.opengee.org/FusionTutorial-Full.tar.gz>
> https://1drv.ms/u/s!AkFDoDHsFe7_hkBS6GbG4xMqnk6t<http://data.opengee.org/Fus
> https://1drv.ms/u/s!AkFDoDHsFe7_hkG1-XDo7UztsPoC<http://data.opengee.org/Fu
Those images are single-tiled, so the GDAL_NUM_THREADS optimization will not help for
them, and current openjpeg versions are super inefficient on those use cases, as GDAL
expose a pseudo tiling to avoid a super big tile size, which cause the whole image to be
decoded multiple times. I'm currently working on improving subtile decoding, that will
substantially improve performance for such images (first steps are already in openjpeg
master, next to follow)
I didn't have the patience to convert the whole image, so just took 3 GDAL blocks of
1024x1024
Without threading support, on hot runs:
gdal_translate bluemarble_4km.jp2 out.tif -srcwin 0 0 3072 1024
35.1 s  GDAL 2.2 / openjpeg 2.1.2
26.2 s  GDAL 2.2 / openjpeg 2.2.0
So I do see an improvement. Not sure why you don't.
Hardware: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
OS: Ubuntu 16.04, 64bit build
and as a teaser:
3.1 s   GDAL 2.2 / openjpeg master
1.5 s   GDAL 2.2 / openjpeg (my work-in-progress branch)
With 8 threads:
9.9 s  GDAL 2.2 / openjpeg 2.2.0
2.3 s  GDAL 2.2 / openjpeg master
0.9 s  GDAL 2.2 / openjpeg (my work-in-progress branch)
With usgsLanSat.jp2
gdal_translate usgsLanSat.jp2 out.tif -srcwin 0 0 3072 1024
40.2 s  GDAL 2.2 / openjpeg 2.1.2
32.3 s  GDAL 2.2 / openjpeg 2.2.0
> p.s: i'm using GDAL 2.1.2
GDAL 2.1 or 2.2 should have comparable performances on this, I think
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170828/ebf0df0e/attachment.html>
