[gdal-dev] Fwd: [OpenJPEG] OpenJPEG 2.2.0 is out ! Faster and safer.
N. Farah
nfarah at hotmail.com
Mon Aug 28 10:21:10 PDT 2017
I rebuilt GDAL (older version: 2.1.2) using this new open jpeg 2.2.0 (https://github.com/uclouvain/openjpeg/releases/download/v2.2.0/openjpeg-v2.2.0-linux-x86_64.tar.gz)
and tried to convert two jp2 dataset to tiff (gdal_translate):
- bluemarble_4km.jp2: (10800 x 5400 pixels). 37.3 mb file size.
- usgsLanSat.jp2: (8627 x 7745 pixels). 48 mb file size.
Tests were run on virtual machine with ‘Ubuntu 16.04’ operation system, 18 gb RAM and 2 CPU processors.
gdal_translate ‘bluemarble_4km.jp2’ to tiff:
- OpenJpeg 2.1.2:
13m34s: first run
13m35s: second run
- OpenJpeg 2.2.0:
13m45: first run
14m20s: second run
gdal_translate ‘usgsLanSat.jp2’ to tiff:
- OpenJpeg 2.1.2:
16m52s: first run
17m04s: second run
- OpenJpeg 2.2.0:
18m13s: first run
17m54s: second run
These results were not expected since the new openJpeg should be faster than the previous one. Could this be cause by 'gdal_translate' not using threads that the new openjpeg uses for performance boost ?
Or could it one of GDAL configuration or the built version of OpenJpeg need to be rebuilt using different config ?
Thanks
Noureddine Farah
Sent: Monday, August 14, 2017 11:42:31 AM
To: Even Rouault; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Fwd: [OpenJPEG] OpenJPEG 2.2.0 is out ! Faster and safer.
Right...since GDAL does not ship the 3rd party lib(s).
Thanks again
Sent: Monday, August 14, 2017 4:49:09 AM
To: gdal-dev at lists.osgeo.org
Cc: N. Farah
On dimanche 13 août 2017 15:57:54 CEST N. Farah wrote:
> Great news. Thanks for the work.
> Any plans to integrate this new version in GDAL ?
Well, there's nothing to change in the GDAL source code. The existing JP2OpenJPEG driver will work with OpenJPEG 2.2. It is just a matter of recompiling libopenjp2.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170828/1cf25515/attachment.html>
