[gdal-dev] openFileGDB driver - polygons with bezier curves not exporting correctly
Even Rouault even.rouault at spatialys.com
Mon Dec 4 04:42:14 PST 2017
> I have been provided with a polygon layer in ESRI FileGDB format
> (created in ArcMap v10.3 at least, maybe 10.4 or 10.4.1). The polygons
> in the layer have been digitised using a mix of straight line segments
> and bezier curves / true arcs, which I've verified in ArcMap by
> looking at the geometry in edit mode.
Lauren,
Bezier curves have no equivalent representation in Single Feature modelling, so they are
linearized as small straight segments. Up to now, 100 intermediate points were used, which
in a case like your dataset was indeed excessive. I've tweaked the logic in trunk to be smarter
(taking into account the angular difference between the start and end tangents, and the
relative length of those tangents vs the direct distance), and now the resulting GPKG from
the conversion is 9 MB, with after a quick visual check is nearly rendered the same as the
previous brute force version
https://trac.osgeo.org/gdal/changeset/40941
Regarding layer geometry types, given that there will be a mix of MultiPolygon and
MultiSurface (MultiSurface due to the polygons with circular portion), and that this cannot be
anticipated before reading the layer content, you may want to either add "-nlt
MULTISURFACE" (that will keep the circular portion as such), or "-nlt MULTIPOLYGON") (to
linearize everything). On your sample dataset, the difference of size is neglectable: 9064448
for the output of -nlt MYLTISURFACE vs 9080832 for the output of -nlt MULTIPOLYGON.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171204/c7c5e593/attachment.html>
