[gdal-dev] Shapefiles and z dimensions
Ari Jolma ari.jolma at gmail.com
Sat Dec 9 03:15:20 PST 2017
Nyall Dawson kirjoitti 09.12.2017 klo 18:04:
> Hi all,
> I'm trying to track down some odd behaviour in QGIS, and determine
> whether this is a qgis bug, gdal bug, or shapefile limitation.
> If I create a new shapefile layer using GDALDatasetCreateLayer, with a
> geometry type of wkbPoint25D (actually any of the 25D) types, then the
> resultant layer ALWAYS has an M dimension present as well (i.e.
> ogrinfo reports PointZM type).
> Is this expected behaviour for shapefiles?
It is expected. Shapefiles are XY, XYM, or XYZM
https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf
Ari
> Nyall
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
