[gdal-dev] gdal make fails for python bindings - with ccache: invalid option -- 'p'
Mark Johnson
mj10777 at googlemail.com
Thu Dec 14 12:30:28 PST 2017
export CXX=/usr/bin/c++
make install
did not resolve this problem.
The WARNING, with ' --tag=CXX /usr/bin/g++ -std=c++11"' still turns up
during setup.py.
gcc -pthread -Wno-unused-result -DNDEBUG -g -fwrapv -O3 -Wall
-Wstrict-prototypes -fPIC -I../../port -I../../gcore -I../../alg
-I../../ogr/ -I../../ogr/ogrsf_frmts -I../../gnm -I../../apps
-I/home/mj10777/000_links/apps_local/libQt592/include/python3.4m
-I/home/mj10777/000_links/apps_local/libQt592/lib/python3.4/site-packages/numpy/core/include
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/include -c
gdal_python_cxx11_test.cpp -o gdal_python_cxx11_test.o -std=c++11
cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for
C/ObjC but not for C++
building 'osgeo._gdal' extension
extensions/gdal_wrap.cpp -o
build/temp.linux-x86_64-3.4/extensions/gdal_wrap.o -std=c++11
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/port
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/gcore
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/alg
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/ogr
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/ogr/ogrsf_frmts
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/frmts/vrt
-I/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/apps
/usr/bin/ccache -pthread -shared
build/temp.linux-x86_64-3.4/extensions/gdal_wrap.o -L../../.libs -L../../
-L/home/mj10777/000_links/apps_local/libQt592/lib
-L/home/mj10777/000_links/gdal_dev/gdal.git/gdal/gdal/lib -lpython3.4m
-lgdal -o build/lib.linux-x86_64-3.4/osgeo/_gdal.cpython-34m.so
/usr/bin/ccache: invalid option -- 'p'
Mark
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171214/d12e1403/attachment.html>
