[gdal-dev] gdal.pc
Ari Jolma ari.jolma at gmail.com
Thu Dec 14 23:54:49 PST 2017
When gdal is built in the Strawberry Perl environment (which includes
MinGW C/C++ compiler gcc) the subsequent use of libgdal in building
other tools (the Perl bindings) is based on using gdal.pc and pkgconfig.
Also, in that environment the linking of gdal with the dependent tools
requires explicit listing of the "dep-libs" - which are available
through the gdal-config but not from gdal.pc.
In linux including the dep-libs in the g++ command is not needed.
I wonder what would be the correct way to fix the problem.
Ari
