[gdal-dev] [gdal-commits] r41044 - trunk/gdal/port
Kurt Schwehr schwehr at gmail.com
Fri Dec 15 14:14:28 PST 2017
Reverted in https://trac.osgeo.org/gdal/changeset/41045
On Fri, Dec 15, 2017 at 3:49 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Ugh.  constexpr would be nice to get started on, but yes, many of the wins
> come in more with C++14 and C++17.
> https://ci.appveyor.com/project/OSGeo/gdal/build/1.0.
> 4152/job/y7fusq8a4lopxpni
> Environment: platform=x86, VSCOMNTOOLS=$(VS120COMNTOOLS),
> SDK=release-1800, MSVC_VER=1800
> cpl_error.cpp
> c:\projects\gdal\gdal\port\cpl_conv.cpp(343) : error C2144: syntax error
> : 'char' should be preceded by ';'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(343) : error C4430: missing type
> specifier - int assumed. Note: C++ does not support default-int
> c:\projects\gdal\gdal\port\cpl_conv.cpp(344) : error C2144: syntax error
> c:\projects\gdal\gdal\port\cpl_conv.cpp(344) : error C4430: missing type
> c:\projects\gdal\gdal\port\cpl_conv.cpp(344) : error C2086: 'int
> constexpr' : redefinition
>         c:\projects\gdal\gdal\port\cpl_conv.cpp(343) : see declaration of
> 'constexpr'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(669) : error C2146: syntax error
> : missing ';' before identifier 'size_t'
> : missing ';' before identifier 'nChunkSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(669) : error C2275: 'size_t' :
> illegal use of this type as an expression
>         c:\projects\gdal\gdal\port\predefined c++ types (compiler
> internal)(19) : see declaration of 'size_t'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(669) : error C2065: 'nChunkSize'
> : undeclared identifier
> c:\projects\gdal\gdal\port\cpl_conv.cpp(670) : error C2065: 'nChunkSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(682) : error C2065: 'nChunkSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(691) : error C2065: 'nChunkSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(702) : error C2065: 'nChunkSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(702) : error C2660: 'VSIFReadL' :
> function does not take 3 arguments
> c:\projects\gdal\gdal\port\cpl_conv.cpp(709) : error C2065: 'nChunkSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(760) : error C2065: 'nChunkSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(1987) : error C2144: syntax error
> c:\projects\gdal\gdal\port\cpl_conv.cpp(1987) : error C4430: missing type
> c:\projects\gdal\gdal\port\cpl_conv.cpp(1987) : error C2086: 'int
> 'constexpr'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(1988) : error C2144: syntax error
> : 'double' should be preceded by ';'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(1988) : error C4430: missing type
> c:\projects\gdal\gdal\port\cpl_conv.cpp(1988) : error C2086: 'int
> 'constexpr'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(2608) : error C2146: syntax error
> : missing ';' before identifier 'nBufferSize'
> c:\projects\gdal\gdal\port\cpl_conv.cpp(2608) : error C2275: 'size_t' :
> c:\projects\gdal\gdal\port\cpl_conv.cpp(2608) : error C2065:
> 'nBufferSize' : undeclared identifier
> c:\projects\gdal\gdal\port\cpl_conv.cpp(2609) : error C2065:
> c:\projects\gdal\gdal\port\cpl_conv.cpp(2624) : error C2065:
> c:\projects\gdal\gdal\port\cpl_conv.cpp(2631) : error C2065:
> cpl_string.cpp
> cplstring.cpp
> On Fri, Dec 15, 2017 at 9:22 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Kurt,
>> It doesn't look like constexpr is available in VS2013 (at least not in
>> all sub-versions of it):
>> https://stackoverflow.com/questions/20264644/constexpr-not-
>> compiling-in-vc2013
>> Personnally, I don't see it as a super needed feature that would justify
>> dropping VS2013 support. Especially in the below use cases where it doesn't
>> bring anything more than const, except more characters to type/read. I'd
>> bet any sane compiler in -O2 will compile the source to the same machine
>> code in all those cases
>> Even
>> On vendredi 15 décembre 2017 07:04:23 CET you wrote:
>> > Author: goatbar
>> > Date: 2017-12-15 07:04:23 -0800 (Fri, 15 Dec 2017)
>> > New Revision: 41044
>> > Modified:
>> > trunk/gdal/port/cpl_conv.cpp
>> > Log:
>> > const -> constexpr for things known at compile time in cpl_conv.cpp
>> > Modified: trunk/gdal/port/cpl_conv.cpp
>> > --- trunk/gdal/port/cpl_conv.cpp 2017-12-15 14:37:43 UTC (rev 41043)
>> > +++ trunk/gdal/port/cpl_conv.cpp 2017-12-15 15:04:23 UTC (rev 41044)
>> > @@ -340,8 +340,8 @@
>> > // ASCII characters.
>> > -static const char knLF = 10;
>> > -static const char knCR = 13;
>> > +constexpr char knLF = 10;
>> > +constexpr char knCR = 13;
>> > * Reads in at most one less than nBufferSize characters from the fp
>> > @@ -666,7 +666,7 @@
>> > /* the line. */
>> > char *pszRLBuffer = nullptr;
>> > - const size_t nChunkSize = 40;
>> > + constexpr size_t nChunkSize = 40;
>> > char szChunk[nChunkSize] = {};
>> > size_t nChunkBytesRead = 0;
>> > int nBufLength = 0;
>> > @@ -1984,8 +1984,8 @@
>> > /* CPLDMSToDec() */
>> > -static const char *sym = "NnEeSsWw";
>> > -static const double vm[] = { 1.0, 0.0166666666667, 0.00027777778 };
>> > +constexpr char sym[] = "NnEeSsWw";
>> > +constexpr double vm[] = { 1.0, 0.0166666666667, 0.00027777778 };
>> > /** CPLDMSToDec */
>> > double CPLDMSToDec( const char *is )
>> > @@ -2605,7 +2605,7 @@
>> > /* Prepare buffer. */
>> > - const size_t nBufferSize = 1024 * 1024;
>> > + constexpr size_t nBufferSize = 1024 * 1024;
>> > GByte *pabyBuffer = static_cast<GByte
>> > *>(VSI_MALLOC_VERBOSE(nBufferSize)); if( pabyBuffer == nullptr )
>> > _______________________________________________
>> > gdal-commits mailing list
>> > gdal-commits at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/gdal-commits
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171215/cb9c0907/attachment-0001.html>
