[gdal-dev] Race condition between forked processes with opened Tiff dataset on Linux
Andrew C Aitchison
andrew at aitchison.me.uk
Fri Dec 15 23:53:01 PST 2017
On Thu, 14 Dec 2017, Jiri Drbalek wrote:
> Hello.
> If a Linux process with opened Tiff dataset is forked, it is not possible
> to read from the dataset concurrently in these forked processes, because
> file offsets and other attributes of the opened Tiff file are shared
> between those processes.
> I've made a patch which optionally close the underlying Tiff file once a
> dataset is opened. One can then fork safely, underlying file is lazily
> opened again in each subprocess.
> What do you think about this problem and proposed solutions? Is there some
> more elegant solution?
Can I assume that we are talking about opening for read and not for write ?
For writing, I was taught that multi-process programs should do all file
writing in a dedicated thread.
Andrew C. Aitchison Cambridge, UK
