[gdal-dev] port/md5 cvs_MD5*
Even Rouault
even.rouault at spatialys.com
Wed Dec 20 06:53:52 PST 2017
On mercredi 20 décembre 2017 06:39:37 CET Kurt Schwehr wrote:
> My personal opinion...
> It was not in fact in the core of GDAL for all users. My primary
> environment does not include the WMS *driver*. My take is that only the
> memory and gtiff raster drivers are really required for GDAL (vector, I'm
> not so sure).
> What do you mean by the same or similar for generic and geojson? And
> because something isn't great elsewhere, that does not mean we want to
> introduce more similar code that is hard to impossible to opt out of.
> Dmitry's question about a reasonable solution is a good one (if you buy my
> being seriously uncomfortable with cvs_MD5*). Possibilities include:
> - Make everything from md5.cpp and md5.h be internal to md5.cpp (aka static
> or inline) and move CPLMD5String to md5.{cpp,h} at least keeping the
> trouble localize
> - Refactor md5 to be cleaner
> - Reimplement md5 hashing for gdal
> - Find some other code that is license compatible that is cleaner
> And why are you exposing this to python? Python has md5 hashing already
> built in.
> Can others please weigh in?
For consistency with the rest, I'd suggest:
- rename md5.* to cpl_md5.*
- rename cvs_MD5* to CPLMD5*
- include cpl_port.h in cpl_md5.h and remove the #if defined(CPL_BASE_H_INCLUDED) stuff.
Currently if someone includes md5.h as the first header, cvs_uint32 will expand to a unsigned
long, whereas the md5.cpp file has been compiled with GUInt32. Not good
Other follow-up cleanups can then be done by interested parties.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171220/27ca01d6/attachment-0001.html>
