[gdal-dev] Change of behavior ?? GDALRasterBand:IReadBlock vs RasterIO ?
asmita
asmitawankhede at gmail.com
Wed Feb 1 10:55:41 PST 2017
I implemented the IReadBlock, still same issue with the WarpOperation ( that
is the code path I am hitting essentially). The issue I see now is the warp
does miss some band info or something happens that the entire mosaic is
black instead of the imagery. Note that these are non pallette imageries :
implementation:
CPLErr XYZRasterBand::IReadBlock(int nBlockXOff, int nBlockYOff, void
*pImage) {
int nXOff = nBlockXOff * nBlockXSize,
nYOff = nBlockYOff * nBlockYSize,
nXSize = nBlockXSize,
nYSize = nBlockYSize;
if( nXOff + nXSize > nRasterXSize )
nXSize = nRasterXSize - nXOff;
if( nYOff + nYSize > nRasterYSize )
nYSize = nRasterYSize - nYOff;
int nPixelSpace = GDALGetDataTypeSize(eDataType) / 8;
int nLineSpace = nPixelSpace * nBlockXSize;
GDALRasterIOExtraArg sExtraArg;
INIT_RASTERIO_EXTRA_ARG(sExtraArg);
return IRasterIO(GF_Read,
nXOff, nYOff, nXSize, nYSize,
pImage, nXSize, nYSize,
eDataType, nPixelSpace, nLineSpace, &sExtraArg);
WarpOperation : region to buffer call:
void
xyzGDALWarpingReader::FetchPixels(const xyzExtents<uint32> &srcExtents)
warpOperation.WarpRegionToBuffer(srcExtents.beginX(),
srcExtents.beginY(),
srcExtents.width(),
srcExtents.height(),
&rawReadBuf[0],
gdalDatatype
srcExtents acts as a destination buffer for whatever reason in the codebase,
and it used to work for GDAL 1.1
View this message in context: http://osgeo-org.1560.x6.nabble.com/Change-of-behavior-GDALRasterBand-IReadBlock-vs-RasterIO-tp5305401p5305837.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
