[gdal-dev] WFS-T using OGR
Ahmed Tolba
Ahmed.Tolba at schiebel.net
Fri Feb 3 00:32:41 PST 2017
Hi Even,
Here is the config.xml file for tinyows. I still can't parse the schema .xsd. For more information, please let me know if you need it.
Ahmed
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Friday, January 27, 2017 12:22 PM
To: Ahmed Tolba
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] WFS-T using OGR
On vendredi 27 janvier 2017 10:59:21 CET Ahmed Tolba wrote:
> Hi
> Thanks for your answer.
> I tried to do what you suggested, but I get " Can not insert the feature,
> because we didn't manage to parse the .XSD schema "
As the message suggests, the OGR WFS client didn't manage to get or correctly parse the schema for the layer. This is a bit surprising as TinyOWS should generate simple enough schemas for OGR to understand them. Difficult to know what happens without being able to reproduce on my side.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170203/cd8077d1/attachment.html>
Type: application/xml
Desc: config.xml
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170203/cd8077d1/attachment.xml>
