[gdal-dev] Zip files and VISFileFromMemBuffer()
Sean Gillies sean at mapbox.com
Fri Feb 3 11:10:14 PST 2017
Yes (as I said off-list), that works too. I've written a post about
Rasterio's MemoryFile and ZipMemoryFile here:
https://github.com/mapbox/rasterio/issues/977. I like GDAL's virtual files
a lot and I think that these classes could make them very accessible to
Python programmers.
On Wed, Feb 1, 2017 at 12:56 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Sean,
> Very cool.  One follow up question, do you really need the "with" for
> open?  Does this not work (and MemoryFile can drop the file descriptor as
> soon as it wants to)?
> with MemoryFile(open(path_zip_file, 'rb')) as memfile:
>         with memfile.open('white-gemini-iv.vrt') as dataset:
>             assert dataset.count == 3
> On Tue, Jan 31, 2017 at 3:35 PM, Sean Gillies <sean at mapbox.com> wrote:
>> Thanks for confirming that I was on the right trail, Even! I got it
>> figured out: I was naively trying to open the /vsizip/vsimem/ file in
>> update mode.
>> In case you're interested, my new Python usage is like this:
>> with open(path_zip_file, 'rb') as f:
>>     with MemoryFile(f) as memfile:
>> https://github.com/mapbox/rasterio/pull/972/files#diff-d3388
>> b510bd97235e4741b8417cc41e9R148
>> On Tue, Jan 31, 2017 at 5:42 PM, Even Rouault <even.rouault at spatialys.com
>> > wrote:
>>> On mardi 31 janvier 2017 17:33:23 CET Sean Gillies wrote:
>>> > Hey all,
>>> > The tests in
>>> > https://svn.osgeo.org/gdal/branches/1.9/autotest/gcore/vsizip.py show
>>> how
>>> > to create a zip archive in memory and create directories and files
>>> within
>>> > it. I'm looking for a shortcut.
>>> > Given a sequence of bytes representing an existing zip file that
>>> contains a
>>> > TIFF and a VRT (referencing the TIFF), is it possible to make a VSI
>>> file
>>> > from this buffer (using VISFileFromMemBuffer()) and then access the VRT
>>> > using a path like /vsizip/vsimem/archive.zip/example.vrt protocol?
>>> Hi Sean,
>>> That sounds like you tested it and something went wrong ? Perhaps check
>>> the path to the source in the VRT and the value of the relativeToVRT
>>> attribute.
>>> Your above strategy does work for me:
>>> $ gdal_translate byte.tif byte.vrt -of VRT
>>> Input file size is 20, 20
>>> $ zip byte.tif.zip byte.tif byte.vrt
>>> adding: byte.tif (deflated 96%)
>>> adding: byte.vrt (deflated 53%)
>>> $ python
>>> >>> from osgeo import gdal
>>> >>> data = open('byte.tif.zip', 'rb').read()
>>> >>> gdal.FileFromMemBuffer('/vsimem/archive.zip', data)
>>> >>> ds = gdal.Open('/vsizip/vsimem/archive.zip/byte.vrt')
>>> >>> ds.GetRasterBand(1).Checksum()
>>> 4672
>>> Even
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>> Sean Gillies
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170203/8718dc2d/attachment.html>
