[gdal-dev] Problem with black edges to DOQQs using JPEG in Tiff compression
Brian Case
rush at winkey.org
Sun Feb 12 13:16:29 PST 2017
Steve,
first, if your data is non lossy you need to nearblack -nb 0 -near 15
however your DOQQ's dont have a collar so there is no reason to
nearblack
gdalwarp -dstalpha will crate an alpha band to mask out the collar after
gdalwarp rotates the image. no nead to nearblack the output of gdal
warp.
when using gdal_translate to create a tiff with a mask band, and you
warped file has a alpha band, gdal_translate -b 1 -b 2 -b 3 -mask 4
this will crate a mask band from the alpha band
brian
On Sat, 2017-02-11 at 18:18 -0500, Stephen Woodbridge wrote:
> Hi All,
> I need your wisdom. I'm downloading NAIP DOQQs in GTiff format and I
> have a processing chain something like the following:
> gdalwarp -t_srs EPSG:4326 -dstalpha -r "bilinear -multi -co TILED=YES
> -dstnodata '0 0 0' srctiff tmpfile
> nearblack -nb 15 -q tmpfile
> gdal_translate -co TILED=YES -co JPEG_QUALITY=90 -co COMPRESS=JPEG -co
> PHOTOMETRIC=YCBCR -b 1 -b 2 -b 3 -mask auto --config
> GDAL_TIFF_INTERNAL_MASK YES tmpfile, target
> nearblack -nb 5 -q target
> gdaladdo -clean -r bilinear target 2 4 8 16 32 64 128 512
> And create a tileindex for mapserver of all the tiffs
> If I skip the gdal_translate (ie: JPEG compression) and the 2nd
> nearblack, the doqq tiles are perfect with no nearblack edges between
> the doqq tiles. But when a JPEG compress them, I get edges between the
> doqqs like this:
> http://imaptools.com:8080/dl/doqq-issue.jpg
> I've never used the JPEG in tiff compression and I'm very impressed by
> the amount of size reduction there and how good the image remains, but I
> have not been able to figure out the magic trick to clearing the edge
> artifacts.
> Any help would be appreciated.
> Thanks,
> -Steve
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
