[gdal-dev] Best way to package and distribute GDAL data files
Emmanuel d'Angelo emmanuel.dangelo at pix4d.com
Tue Feb 14 07:12:55 PST 2017
Thanks Ari for the interest!
Unfortunately, my target is to ship for all 3 major OSes (linux, windows, macOS).
Regarding my build system, everything is glued by cmake. Not sure if it's related, but I build (for now) GDAL as a dynamic lib and PROJ4 as a static one. Any change here is possible if it helps with the issue.
Emmanuel
> Le 14 févr. 2017 à 15:52, Ari Jolma <ari.jolma at gmail.com> a écrit :
> Emmanuel,
> I think we need to know the OS you're using.
> Ari
> 14.02.2017, 16:48, Emmanuel d'Angelo kirjoitti:
>> Dear list,
>> I'm trying to package and distribute an application that relies internally on GDAL for some raster / vector manipulation.
>> It may happen in some cases that a user of the application wants to take her outputs to a different coordinate system (typically from some national system to WGS84). As far as I can see, some of these transformations rely on the content of GDAL data files (such as pcs.csv or datum.csv).
>> I can install these files locally and use the GDAL_DATA environment variable to find them from my application. However, on the user side, what's the recommended practice?
>> Do I need to ensure that my users have a GDAL_DATA variable set too with the correct data files? I've looked at the build system files, but I couldn't find a way to set this path relative to my application (which would let me install these files inside the app package and distribute them with the application).
>> Any hint to put me on the right track would be greatly appreciated.
>> Best regards,
>> Emmanuel
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170214/25762657/attachment.html>
