[gdal-dev] Placemark With Two Geometries Is Not Processed
archgnulinux
philip.d.kahly at leidos.com
Wed Feb 15 10:27:54 PST 2017
Even Rouault-2 wrote
> You mention Windows, but your nickname is archgnulinux... So assuming the
> later, the GDAL 2.1.2 package in UbuntuGIS unstable for Xenial is built
> against libkml.
> And I also see that the GDAL package in OSGEO4W has the libkml dependency.
Unfortunately, I have to use Windows for this...
OSGEO4W didn't have the 2.1 version, but I found a package on GISInternals
and it works.
Thanks for you help.
Philip
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Placemark-With-Two-Geometries-Is-Not-Processed-tp5308067p5308098.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
