[gdal-dev] Building GDAL with PROJ4 in a non-standard location?
Emmanuel d'Angelo emmanuel.dangelo at pix4d.com
Thu Feb 16 07:48:57 PST 2017
Hi everyone,
I'm experimenting with a C++ package manager (conan.io for interested
folks) to correctly setup my project and its dependencies.
In this experiment, I'm trying to wrap GDAL and build GDAL 2.1.1 using a
PROJ4 library that was put in a non-standard location by the package
manager. When I had a look at the configure.in file, I could find an option
to specify the path to PROJ4 install directory, but that is only set when
using the option --with-static-proj4.
Is there a way to pass the path to a dynamic library of PROJ4 when building
GDAL?
Thanks a lot,
Emmanuel
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170216/b7896a67/attachment.html>
