[gdal-dev] Fwd: Re: GDAL unable to write 4-band RGBA jp2 file with Kakadu 7.8
Kurt Schwehr
schwehr at gmail.com
Sat Feb 18 05:14:17 PST 2017
Well, I made a start as a part of gdal-autotest2...
https://github.com/schwehr/gdal-autotest2/blob/master/cpp/third_party/kakadu/coresys/common/kdu_arch_test.cc
On Sat, Feb 18, 2017 at 5:03 AM, Aaron Boxer <boxerab at gmail.com> wrote:
> ---------- Forwarded message ----------
> From: "Aaron Boxer" <boxerab at gmail.com>
> Date: Feb 18, 2017 8:03 AM
> Subject: Re: [gdal-dev] GDAL unable to write 4-band RGBA jp2 file with
> Kakadu 7.8
> To: "Kurt Schwehr" <schwehr at gmail.com>
> Cc:
> On Feb 18, 2017 7:26 AM, "Kurt Schwehr" <schwehr at gmail.com> wrote:
> Jason,
> Turns out you are hitting a known bug in v7.8 that is fixed in v7.9. From
> the kakadu v7.9 docs:
> h. Corrected a tiny, yet very significant bug introduced into the
> handling of opacity channel descriptions in version 7.8. The
> correction is in function `jp2_channels::set_opacity_mapping', where
> the opacity channel's component index accidentally overwrote the
> colour channel's component index.
> Apparently Kakadu does no regression testing before a release 😁
> It's pretty easy to backport the fix if you are currently stuck at 7.8.
> It's just a change of a 0 to a 1.
> --- kakadu/v7_8/apps/jp2/jp2.cpp
> +++ kakadu/v7_9/apps/jp2/jp2.cpp
> @@ -5976,7 +5976,7 @@
> if (lut_idx < 0)
> lut_idx = -1; // For consistency in comparisons later on.
> j2_channels::j2_channel *cp = state->channels+colour_idx;
> - cp->component_idx[0] = codestream_component;
> + cp->component_idx[1] = codestream_component; /* Was a bug in version
> 7.8 */
> cp->lut_idx[1] = lut_idx;
> cp->codestream_idx[1] = codestream_idx;
> cp->data_format[1] = data_format;
> The 0 can trigger an error that looks just like you are seeing:
> Error: GdalIO: Error in Kakadu File Format Support: Attempting to create a
> Component Mapping (cmap) box, one of whose channels refers to a
> non-existent image component or palette lookup table. (code = 1)
> On Mon, Feb 13, 2017 at 9:28 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
>> Hi Jason,
>> I've seen the same thing with an alpha channel. I'm not sure what's up.
>> Using just RGB was successful.
>> On 7.3, I'm also seeing problems when using more than the main thread on
>> linux.
>> With 7.3, I just noticed today that kdu_get_num_processors() only returns
>> 0 on linux as kdu_arch.cpp is missing #include <unistd.h> so
>> _SC_NPROCESSORS_ONLN and _SC_NPROCESSORS_CONF are undefined. When I
>> enabled _SC_NPROCESSORS_ONLN, I got kdu_get_num_processors() returning 74
>> on what I thought was a 6 core (aka 12 hyperthread) box. If I change the
>> fall through from 0 to 2, I get all sorts of trouble from internal kakadu
>> assertions and TSAN failures.
>> So I clearly have more investigating to do.
>> I've yet to pass along any of what I've found to Taubman and I haven't
>> yet pushed any of my new tests to github, but I hope to do both soon.
>> And I've yet to see what, if any, discussion is happening in the yahoo
>> group.
>> -kurt
>> On Mon, Feb 13, 2017 at 8:14 PM, jason.liu <jason.liu at spookfish.com>
>> wrote:
>>> Hi gdal-dev,
>>> I am having trouble using GDAL to write 4-band RGBA jp2 file with Kakadu
>>> 7.8. The following minimal code
>>> GDALAllRegister();
>>> GDALDataset* srcDataset =
>>> (GDALDataset*)GDALOpen("/home/jason.liu/00000783.tif", GA_ReadOnly);
>>> char **papszOptions = NULL;
>>> papszOptions = CSLSetNameValue( papszOptions, "QUALITY", "20" );
>>> GDALDriver *driver = GetGDALDriverManager()->GetDri
>>> verByName("JP2KAK");
>>> GDALDataset* destDataset =
>>> driver->CreateCopy("/home/jason.liu/00000783.jp2",
>>> srcDataset,
>>> FALSE,
>>> papszOptions,
>>> NULL,
>>> NULL);
>>> if( destDataset != NULL ) {
>>> GDALClose( (GDALDatasetH) destDataset );
>>> GDALClose( (GDALDatasetH) srcDataset );
>>> CSLDestroy(papszOptions);
>>> crashes Kakadu 7.8 with the following message in stderr:
>>> ERROR 1: Error in Kakadu File Format Support:
>>> Attempting to create a Component Mapping (cmap) box, one of whose
>>> channels
>>> refers to a non-existent image component or palette lookup table.
>>> terminate called after throwing an instance of
>>> 'kdu_cpl_error_message::JP2KAKException'
>>> where /home/jason.liu/00000783.tif is a 4-band 16-bit RGBA tif.
>>> I have also done the following tests and noted the results:
>>> 3-band 8-bit RGB tif OK
>>> 3-band 16-bit RGB tif OK
>>> 4-band 8-bit RGBA tif error as above
>>> 4-band 16-bit RGBA tif error as above
>>> Am I doing anything wrong here?
>>> By the way, I am quite certain Kakadu 7.8 supports 4-band RGBA as I can
>>> use
>>> their example kdu_compress to produce 4-band RGBA jp2 images. So this
>>> looks
>>> to be a problem with GDAL, or the way I am invoking it.
>>> Any insights will be greatly appreciated.
>>> Kind Regards
>>> Jason
>>> View this message in context: http://osgeo-org.1560.x6.nabbl
>>> e.com/GDAL-unable-to-write-4-band-RGBA-jp2-file-with-Kakadu-
>>> 7-8-tp5307801.html
>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://schwehr.org
> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170218/45d851d6/attachment-0001.html>
