[gdal-dev] Fwd: Re: GDAL unable to write 4-band RGBA jp2 file with Kakadu 7.8
Kurt Schwehr
schwehr at gmail.com
Mon Feb 20 10:56:16 PST 2017
Only 370K more LOC left to cover with proper library level unittests.
On Mon, Feb 20, 2017 at 10:01 AM, Aaron Boxer <boxerab at gmail.com> wrote:
> On Sat, Feb 18, 2017 at 8:14 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
>> Well, I made a start as a part of gdal-autotest2...
>> https://github.com/schwehr/gdal-autotest2/blob/master/cpp/
>> third_party/kakadu/coresys/common/kdu_arch_test.cc
> That is a good start.
>> On Sat, Feb 18, 2017 at 5:03 AM, Aaron Boxer <boxerab at gmail.com> wrote:
>>> ---------- Forwarded message ----------
>>> From: "Aaron Boxer" <boxerab at gmail.com>
>>> Date: Feb 18, 2017 8:03 AM
>>> Subject: Re: [gdal-dev] GDAL unable to write 4-band RGBA jp2 file with
>>> Kakadu 7.8
>>> To: "Kurt Schwehr" <schwehr at gmail.com>
>>> Cc:
>>> On Feb 18, 2017 7:26 AM, "Kurt Schwehr" <schwehr at gmail.com> wrote:
>>> Jason,
>>> Turns out you are hitting a known bug in v7.8 that is fixed in v7.9.
>>> From the kakadu v7.9 docs:
>>> h. Corrected a tiny, yet very significant bug introduced into the
>>> handling of opacity channel descriptions in version 7.8. The
>>> correction is in function `jp2_channels::set_opacity_mapping', where
>>> the opacity channel's component index accidentally overwrote the
>>> colour channel's component index.
>>> Apparently Kakadu does no regression testing before a release 😁
>>> It's pretty easy to backport the fix if you are currently stuck at 7.8.
>>> It's just a change of a 0 to a 1.
>>> --- kakadu/v7_8/apps/jp2/jp2.cpp
>>> +++ kakadu/v7_9/apps/jp2/jp2.cpp
>>> @@ -5976,7 +5976,7 @@
>>> if (lut_idx < 0)
>>> lut_idx = -1; // For consistency in comparisons later on.
>>> j2_channels::j2_channel *cp = state->channels+colour_idx;
>>> - cp->component_idx[0] = codestream_component;
>>> + cp->component_idx[1] = codestream_component; /* Was a bug in version
>>> 7.8 */
>>> cp->lut_idx[1] = lut_idx;
>>> cp->codestream_idx[1] = codestream_idx;
>>> cp->data_format[1] = data_format;
>>> The 0 can trigger an error that looks just like you are seeing:
>>> Error: GdalIO: Error in Kakadu File Format Support: Attempting to create
>>> a Component Mapping (cmap) box, one of whose channels refers to a
>>> non-existent image component or palette lookup table. (code = 1)
>>> On Mon, Feb 13, 2017 at 9:28 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
>>>> Hi Jason,
>>>> I've seen the same thing with an alpha channel. I'm not sure what's
>>>> up. Using just RGB was successful.
>>>> On 7.3, I'm also seeing problems when using more than the main thread
>>>> on linux.
>>>> With 7.3, I just noticed today that kdu_get_num_processors() only
>>>> returns 0 on linux as kdu_arch.cpp is missing #include <unistd.h> so
>>>> _SC_NPROCESSORS_ONLN and _SC_NPROCESSORS_CONF are undefined. When I
>>>> enabled _SC_NPROCESSORS_ONLN, I got kdu_get_num_processors() returning 74
>>>> on what I thought was a 6 core (aka 12 hyperthread) box. If I change the
>>>> fall through from 0 to 2, I get all sorts of trouble from internal kakadu
>>>> assertions and TSAN failures.
>>>> So I clearly have more investigating to do.
>>>> I've yet to pass along any of what I've found to Taubman and I haven't
>>>> yet pushed any of my new tests to github, but I hope to do both soon.
>>>> And I've yet to see what, if any, discussion is happening in the yahoo
>>>> group.
>>>> -kurt
>>>> On Mon, Feb 13, 2017 at 8:14 PM, jason.liu <jason.liu at spookfish.com>
>>>> wrote:
>>>>> Hi gdal-dev,
>>>>> I am having trouble using GDAL to write 4-band RGBA jp2 file with
>>>>> Kakadu
>>>>> 7.8. The following minimal code
>>>>> GDALAllRegister();
>>>>> GDALDataset* srcDataset =
>>>>> (GDALDataset*)GDALOpen("/home/jason.liu/00000783.tif", GA_ReadOnly);
>>>>> char **papszOptions = NULL;
>>>>> papszOptions = CSLSetNameValue( papszOptions, "QUALITY", "20" );
>>>>> GDALDriver *driver = GetGDALDriverManager()->GetDri
>>>>> verByName("JP2KAK");
>>>>> GDALDataset* destDataset =
>>>>> driver->CreateCopy("/home/jason.liu/00000783.jp2",
>>>>> srcDataset,
>>>>> FALSE,
>>>>> papszOptions,
>>>>> NULL,
>>>>> NULL);
>>>>> if( destDataset != NULL ) {
>>>>> GDALClose( (GDALDatasetH) destDataset );
>>>>> GDALClose( (GDALDatasetH) srcDataset );
>>>>> CSLDestroy(papszOptions);
>>>>> crashes Kakadu 7.8 with the following message in stderr:
>>>>> ERROR 1: Error in Kakadu File Format Support:
>>>>> Attempting to create a Component Mapping (cmap) box, one of whose
>>>>> channels
>>>>> refers to a non-existent image component or palette lookup table.
>>>>> terminate called after throwing an instance of
>>>>> 'kdu_cpl_error_message::JP2KAKException'
>>>>> where /home/jason.liu/00000783.tif is a 4-band 16-bit RGBA tif.
>>>>> I have also done the following tests and noted the results:
>>>>> 3-band 8-bit RGB tif OK
>>>>> 3-band 16-bit RGB tif OK
>>>>> 4-band 8-bit RGBA tif error as above
>>>>> 4-band 16-bit RGBA tif error as above
>>>>> Am I doing anything wrong here?
>>>>> By the way, I am quite certain Kakadu 7.8 supports 4-band RGBA as I
>>>>> can use
>>>>> their example kdu_compress to produce 4-band RGBA jp2 images. So this
>>>>> looks
>>>>> to be a problem with GDAL, or the way I am invoking it.
>>>>> Any insights will be greatly appreciated.
>>>>> Kind Regards
>>>>> Jason
>>>>> View this message in context: http://osgeo-org.1560.x6.nabbl
>>>>> e.com/GDAL-unable-to-write-4-band-RGBA-jp2-file-with-Kakadu-
>>>>> 7-8-tp5307801.html
>>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> http://schwehr.org
>>> http://schwehr.org
>> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170220/5d489dca/attachment.html>
