[gdal-dev] gdal-autotest2
Kurt Schwehr
schwehr at gmail.com
Mon Feb 20 11:57:53 PST 2017
Well, it would be great if the GDAL community wants to merge that code. I
wanted to get a big enough body of code that people could get a sense of it
before suggesting any kind of merge.
But anyway it goes, it's a win for me. It's what I run my continuous
integration against in the custom environment I'm responsible for. And
it's the code that makes merging from svn manageable. It's running for all
dependent lib and tool chain changes many times an hour and also runs as
hardened, asan, msan, and tsan.
On Mon, Feb 20, 2017 at 11:26 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 20 février 2017 10:56:16 CET Kurt Schwehr wrote:
> > Only 370K more LOC left to cover with proper library level unittests.
> Changing the topic line.
> Kurt
> IHMO if your aim is to have gdal-autotest2 being merged some day, the
> forked approach is going to be a nightmare for you to manage, unless you
> have a huge workforce to put behind. I'd rather attempt at having the
> current autotest suite running as a hack into the cleaner approach, so it
> can be merged into trunk and once done, migrate things progressively.
> Even
> > On Mon, Feb 20, 2017 at 10:01 AM, Aaron Boxer <boxerab at gmail.com> wrote:
> > > On Sat, Feb 18, 2017 at 8:14 AM, Kurt Schwehr <schwehr at gmail.com>
> wrote:
> > >> Well, I made a start as a part of gdal-autotest2...
> > >> https://github.com/schwehr/gdal-autotest2/blob/master/cpp/
> > >> third_party/kakadu/coresys/common/kdu_arch_test.cc
> > > That is a good start.
> > >> On Sat, Feb 18, 2017 at 5:03 AM, Aaron Boxer <boxerab at gmail.com>
> wrote:
> > >>> ---------- Forwarded message ----------
> > >>> From: "Aaron Boxer" <boxerab at gmail.com>
> > >>> Date: Feb 18, 2017 8:03 AM
> > >>> Subject: Re: [gdal-dev] GDAL unable to write 4-band RGBA jp2 file
> with
> > >>> Kakadu 7.8
> > >>> To: "Kurt Schwehr" <schwehr at gmail.com>
> > >>> Cc:
> > >>> On Feb 18, 2017 7:26 AM, "Kurt Schwehr" <schwehr at gmail.com> wrote:
> > >>> Jason,
> > >>> Turns out you are hitting a known bug in v7.8 that is fixed in v7.9.
> > >>> From the kakadu v7.9 docs:
> > >>> h. Corrected a tiny, yet very significant bug introduced into the
> > >>> handling of opacity channel descriptions in version 7.8. The
> > >>> correction is in function `jp2_channels::set_opacity_mapping', where
> > >>> the opacity channel's component index accidentally overwrote the
> > >>> colour channel's component index.
> > >>> Apparently Kakadu does no regression testing before a release 😁
> > >>> It's pretty easy to backport the fix if you are currently stuck at
> 7.8.
> > >>> It's just a change of a 0 to a 1.
> > >>> --- kakadu/v7_8/apps/jp2/jp2.cpp
> > >>> +++ kakadu/v7_9/apps/jp2/jp2.cpp
> > >>> @@ -5976,7 +5976,7 @@
> > >>> if (lut_idx < 0)
> > >>> lut_idx = -1; // For consistency in comparisons later on.
> > >>> j2_channels::j2_channel *cp = state->channels+colour_idx;
> > >>> - cp->component_idx[0] = codestream_component;
> > >>> + cp->component_idx[1] = codestream_component; /* Was a bug in
> version
> > >>> 7.8 */
> > >>> cp->lut_idx[1] = lut_idx;
> > >>> cp->codestream_idx[1] = codestream_idx;
> > >>> cp->data_format[1] = data_format;
> > >>> The 0 can trigger an error that looks just like you are seeing:
> > >>> Error: GdalIO: Error in Kakadu File Format Support: Attempting to
> create
> > >>> a Component Mapping (cmap) box, one of whose channels refers to a
> > >>> non-existent image component or palette lookup table. (code = 1)
> > >>> On Mon, Feb 13, 2017 at 9:28 PM, Kurt Schwehr <schwehr at gmail.com>
> wrote:
> > >>>> Hi Jason,
> > >>>> I've seen the same thing with an alpha channel. I'm not sure what's
> > >>>> up. Using just RGB was successful.
> > >>>> On 7.3, I'm also seeing problems when using more than the main
> thread
> > >>>> on linux.
> > >>>> With 7.3, I just noticed today that kdu_get_num_processors() only
> > >>>> returns 0 on linux as kdu_arch.cpp is missing #include <unistd.h> so
> > >>>> _SC_NPROCESSORS_ONLN and _SC_NPROCESSORS_CONF are undefined. When I
> > >>>> enabled _SC_NPROCESSORS_ONLN, I got kdu_get_num_processors()
> returning
> > >>>> 74
> > >>>> on what I thought was a 6 core (aka 12 hyperthread) box. If I change
> > >>>> the
> > >>>> fall through from 0 to 2, I get all sorts of trouble from internal
> > >>>> kakadu
> > >>>> assertions and TSAN failures.
> > >>>> So I clearly have more investigating to do.
> > >>>> I've yet to pass along any of what I've found to Taubman and I
> haven't
> > >>>> yet pushed any of my new tests to github, but I hope to do both
> soon.
> > >>>> And I've yet to see what, if any, discussion is happening in the
> yahoo
> > >>>> group.
> > >>>> -kurt
> > >>>> On Mon, Feb 13, 2017 at 8:14 PM, jason.liu <jason.liu at spookfish.com
> > >>>> wrote:
> > >>>>> Hi gdal-dev,
> > >>>>> I am having trouble using GDAL to write 4-band RGBA jp2 file with
> > >>>>> Kakadu
> > >>>>> 7.8. The following minimal code
> > >>>>> GDALAllRegister();
> > >>>>> GDALDataset* srcDataset =
> > >>>>> (GDALDataset*)GDALOpen("/home/jason.liu/00000783.tif",
> GA_ReadOnly);
> > >>>>> char **papszOptions = NULL;
> > >>>>> papszOptions = CSLSetNameValue( papszOptions, "QUALITY", "20" );
> > >>>>> GDALDriver *driver = GetGDALDriverManager()->GetDri
> > >>>>> verByName("JP2KAK");
> > >>>>> GDALDataset* destDataset =
> > >>>>> driver->CreateCopy("/home/jason.liu/00000783.jp2",
> > >>>>> srcDataset,
> > >>>>> FALSE,
> > >>>>> papszOptions,
> > >>>>> NULL,
> > >>>>> NULL);
> > >>>>> if( destDataset != NULL ) {
> > >>>>> GDALClose( (GDALDatasetH) destDataset );
> > >>>>> GDALClose( (GDALDatasetH) srcDataset );
> > >>>>> CSLDestroy(papszOptions);
> > >>>>> crashes Kakadu 7.8 with the following message in stderr:
> > >>>>> ERROR 1: Error in Kakadu File Format Support:
> > >>>>> Attempting to create a Component Mapping (cmap) box, one of whose
> > >>>>> channels
> > >>>>> refers to a non-existent image component or palette lookup table.
> > >>>>> terminate called after throwing an instance of
> > >>>>> 'kdu_cpl_error_message::JP2KAKException'
> > >>>>> where /home/jason.liu/00000783.tif is a 4-band 16-bit RGBA tif.
> > >>>>> I have also done the following tests and noted the results:
> > >>>>> 3-band 8-bit RGB tif OK
> > >>>>> 3-band 16-bit RGB tif OK
> > >>>>> 4-band 8-bit RGBA tif error as above
> > >>>>> 4-band 16-bit RGBA tif error as above
> > >>>>> Am I doing anything wrong here?
> > >>>>> By the way, I am quite certain Kakadu 7.8 supports 4-band RGBA as I
> > >>>>> can use
> > >>>>> their example kdu_compress to produce 4-band RGBA jp2 images. So
> this
> > >>>>> looks
> > >>>>> to be a problem with GDAL, or the way I am invoking it.
> > >>>>> Any insights will be greatly appreciated.
> > >>>>> Kind Regards
> > >>>>> Jason
> > >>>>> View this message in context: http://osgeo-org.1560.x6.nabbl
> > >>>>> e.com/GDAL-unable-to-write-4-band-RGBA-jp2-file-with-Kakadu-
> > >>>>> 7-8-tp5307801.html
> > >>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > >>>>> _______________________________________________
> > >>>>> gdal-dev mailing list
> > >>>>> gdal-dev at lists.osgeo.org
> > >>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> > >>>> http://schwehr.org
> > >>> http://schwehr.org
> > >> http://schwehr.org
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170220/284fe454/attachment-0001.html>
