[gdal-dev] configure: WARNING: unrecognized options: --with-macosx-framework
Even Rouault
even.rouault at spatialys.com
Tue Jan 3 02:55:49 PST 2017
> Anyway, should I file a bug and commit the above path to the file
> "configure"?
configure should never been manually modified. It is regenerated by autoconf (currently
2.69) from configure.in
I've traced the issue to be linked to the following line in configure.in
AC_ARG_WITH(,[ --with-macosx-framework Build and install GDAL as a Mac OS X
Framework],,)
Changing it to
AC_ARG_WITH(macosx-framework,[ --with-macosx-framework Build and install GDAL as
a Mac OS X Framework],,)
seems to solve the issue.
Surprisingly, the AC_ARG_WITH(,[ ....]) syntax has been used since
https://trac.osgeo.org/gdal/changeset/10196 , so perhaps the warning has always existed, or
autoconf is less tolerant now. Who knows.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170103/87eced36/attachment.html>
