[gdal-dev] C++11 timeline
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jan 5 12:23:35 PST 2017
MS4W builds are moving to VS2015, because PHP 7's requirement for that
compiler, but stable releases are done now with VS2012.  (I've
officially moved away from the old VS2008)
-jeff
Jeff McKenna
President Emeritus, OSGeo Foundation
http://wiki.osgeo.org/wiki/Jeff_McKenna
On 2017-01-05 1:26 PM, Even Rouault wrote:
>> What is the list of compilers that GDAL actively and accidentally
> supports?
> Currently, at least:
> GCC >= 4.4 (actually must be 4.1 since this is what ancient mingw uses)
> clang >= 3.something (3.0 probably)
> VS >= 2008
> ICC 15 probably
> One aspect is to also consider the various analyzers used. I think
> cppcheck has only partial C++11 support. I'd guess Coverity Scan should
> have decent C++11 support but this is just a guess. CLang Static
> Analyzer should likely work just fine with the C++11 supported by the
> underlying clang compiler
>> How will that be impacted by a C++11 requirement?
> GCC 4.8 is needed for C++11 I think. There are folks using recent GDAL
> on older distros like Ubuntu 12.04 (which ships with gcc 4.6). I guess
> they could switch to adding a PPA with a more recent toolchain.
> For Visual Studio depends on the features we use. Would be good to have
> VS2013 or even 2012. I'm CC'ing Jürgen Fischer to know if he has plans
> regarding of the compiler version that will be used for OSGeo4W / QGIS 3.0
> Even
