[gdal-dev] How does OGRFeature::GetFieldAsDouble handle NULL values
Paul Meems
bontepaarden at gmail.com
Thu Jan 5 23:44:39 PST 2017
Thanks Nyall,
Looking at the documentation it seems to be what I'm looking for.
Thanks,
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
*The MapWindow GIS project has moved to GitHub
<https://github.com/MapWindow>!*
Download the latest MapWinGIS mapping engine.
<https://github.com/MapWindow/MapWinGIS/releases>
Download the latest MapWindow 5 open source desktop application.
<https://github.com/MapWindow/MapWindow5/releases>
2017-01-05 23:24 GMT+01:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 6 Jan 2017 7:37 AM, "Paul Meems" <bontepaarden at gmail.com> wrote:
> We're using GDAL v2.1.2 on Windows.
> We use the GDAL library with MapWinGIS to connect to a PostGIS database.
> When the PostGIS table has NULL values in integer, numeric or double
> fields and that data is read the returned values are 0 (zero), which is
> unexpected by us.
> We use Feature->GetFieldAsDouble() and Feature->GetFieldAsInteger().
> Am I correct that these function return 0 when the database value is NULL?
> If not our implementation is wrong and I need to continue my search.
> The documentation http://www.gdal.org/classOGRFe
> ature.html#ab8a57c94e8bb8ffac5e7048d896254b4 doesn't say either way.
> Try Feature->IsFieldSet(...)
> http://www.gdal.org/classOGRFeature.html#a7ad01c76b7b13bcf9eab5092aacac5fb
> That should return false for null values.
> Nyall
> Thanks,
> Paul
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170106/3611c48e/attachment.html>
