[gdal-dev] Question on 0th IFD offset when producing a JPEG-Compressed GeoTIFF (GDAL 1.11 vs 2.x)
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Tue Jan 10 02:00:19 PST 2017
Hi Even.
I'm back to the topic :)
Do you have any timeframe for the 2.2.x release?
Best Regards,
Daniele
On Fri, Dec 16, 2016 at 2:56 PM, Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> On Fri, Dec 16, 2016 at 2:48 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> > Right,
>> > Indeed, before sending my previous email I have also tried with:
>> > *gdaladdo -r average --config COMPRESS_OVERVIEW DEFLATE --config
>> > PHOTOMETRIC_OVERVIEW RGB*
>> > to understand if it was related to JPEG only but, even with these
>> options,
>> > the output overviews were jpeg compressed (I assume there is some kind
>> of
>> > coherency check in gdaladdo).
>> With internal overviews, the _OVERVIEW configuration options are ignored.
>> Their value is deduced from the settings of the main IFD.
> It makes sense, indeed.
>> I don't think there's a strong technical reason for that. Mostly a side
>> effect of the fact that there are slightly different code paths to handle
>> creation of internal and external overviews, and the reading of _OVERVIEW
>> config options is done only in the external overview code path.
>> > > I do reproduce something similar to your findings in 2.1 indeed. This
>> no
>> > > longer happens in trunk due to related improvements (
>> > > https://trac.osgeo.org/gdal/wiki/CloudOptimizedGeoTIFF), I made in
>> the
>> > > last couple of weeks (using the same trick of creating a in-memory
>> TIFF
>> > > file to get the JPEG tables and set them direcly on the overview IFD
>> at
>> > > creation time).
>> > Do you think this will be available in other series or does it introduce
>> > new API/major changes which makes it available on 2.2.x only?
>> No API change, but this is in the improvement category rather than
>> bugfixing, and my first changeset resulted in some corrupted images in some
>> situations, which was unnoticed for a few weeks, so that's a sign that it
>> is a somewhat risky change (the GeoTIFF driver is a complex beast), not
>> worth the trouble of breaking stable branches.
> Understood. thanks for the feedback.
> Cheers,
> Daniele
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:      +39 0584 1660272 <+39%200584%20166%200272>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
GeoSolutions S.A.S.
Italy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170110/5fb21602/attachment.html>
