[gdal-dev] C++11 timeline
Greg Troxel
gdt at lexort.com
Thu Jan 12 08:57:13 PST 2017
Kurt Schwehr <schwehr at gmail.com> writes:
> Greg,
> Can you explain the use case as to what keeps you on an older NetBSD but
> unable to use a branch of a recent GDAL? e.g. I'm am suggesting that we
> keep GDAL 2.1 and older to stay with the current requirement of supporting
> C++03.
That is probably ok. I should point out that I'm coming at this as a
packager - I look after a number of geo packages in pkgsrc, which
supports multiple versions of multiple operating systems, causing it to
run into more portability issues than packages for a particular Linux
distribution. (My actual use of GDAL is so far not extensive and I can
certainly run it on a newer release.)
My concern is really that once there is a GDAL release that needs a
newer compiler, then some other program will require that version of
GDAL. As a packager, I more or less have to decide whether to update
each program, balancing users getting new stuff and
stability/portability.
If no other packages start to depend on unreleased GDAL, and the first
GDAL release requiring C++11 is a ways off, and by then enough other
things require it that a system not having a C++11 compiler is totally
non-viable, then this shouldn't cause problems for pkgsrc.
> As for boost, my experiences are that would be far more effort support it
> on many platforms than getting a working C++11 compiler. Boost is full of
> really awesome code, but there be dragons and really careful consideration
> should be made before requiring boost for any code that will have to be
> linked against by other libraries.
OK - thanks for explaining.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170112/6a57ace2/attachment.sig>
