[gdal-dev] C++11 timeline
Greg Troxel
gdt at lexort.com
Thu Jan 12 17:55:53 PST 2017
Kurt Schwehr <schwehr at gmail.com> writes:
> Thanks Gred and Andrew! Those are exactly the kind of comments that help.
> Greg,
> I have lots of experience packaging GDAL in fink for the mac, but less
> elsewhere. I found this like which implies that pkgsrc is at GDAL 1.11.3.
> Are there better links?
Yes, it's behind, for no good reason. I need to update it. I might
have tried and found it non-trivial, but I don't remember clearly.
> - http://pkgsrc.se/geography/gdal-lib
That's a good link. Canonical http pointer at:
http://cvsweb.netbsd.org/bsdweb.cgi/pkgsrc/geography/gdal-lib/
Also, this shows build status on a lot of platforms (but a small
fraction of the set pkgsrc is intended to work on):
https://bulktracker.appspot.com/pkgresults/geography/gdal-lib
> - https://github.com/joyent/pkgsrc/blob/trunk/geography/gdal-lib/Makefile
That's a soft fork, intending to have a few diffs but not much. The
vast majority of things are the same, especially normal packages like
gdal-lib.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170112/e1c6d65c/attachment.sig>
