[gdal-dev] C++11 timeline
Greg Troxel gdt at lexort.com
Fri Jan 13 16:15:27 PST 2017
Jürgen E. Fischer <jef at norbit.de> writes:
> On Fri, 13. Jan 2017 at 06:42:26 +1000, Nyall Dawson wrote:
>> FYI - the upcoming QGIS 3.0 release has a hard c++11 requirement. Not
>> sure how much that affects things, but certainly projects which
>> utilise GDAL are already switching to c++11.
> We're not using the C++ API - so that shouldn't matter.
I took the comment to mean that since QGIS would require c++11, if you
wanted to run QGIS, you'd ned to cope with a new-enough compiler, in
which case GDAL also needing it would not be an incremental burden.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170113/93e55820/attachment.sig>
