[gdal-dev] GDAL S57 "New Object"
Even Rouault even.rouault at spatialys.com
Tue Jan 17 00:08:58 PST 2017
On mardi 17 janvier 2017 07:48:45 CET Jerome Siot wrote:
> Hi,
> Implementing a program using gdal 2.0.1, I trap an exception on a
> GetNextFeature() call, on layer id 163 "NEW OBJECT", described on
> www.s-57.com<http://www.s-57.com>. As a first idea, I read
> gdal/gdal/data/s57objectclasses.csv (from
> https://github.com/OSGeo/gdal/commits/trunk/gdal/data/s57objectclasses.csv)
> => this file has no description for "New Object"
> Any idea ?
Jerome,
It looks like you spotted the issue. Would you mind submitting a patch with the new entry in
the file ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170117/878f73dd/attachment-0001.html>
