[gdal-dev] Question about .aux.xml sidecar file handling...
Carl Godkin
cgodkin at gmail.com
Wed Jan 18 06:55:49 PST 2017
I have a geological map in a pair of files called USGS.tif and
USGS.tif.aux.xml
The XML seems to have ground control points (<SourceGCPs>) and a geographic
coordinate system (<SpatialReference>)
I was hoping that GDAL would treat the file as if it's a GeoTIFF. But if I
run gdalinfo on the .tif, it doesn't seem to read the coordinate system or
GCPs. Instead, I see this:
Driver: GTiff/GeoTIFF
Files: USGS.tif
USGS.tif.aux.xml
Size is 11451, 12188
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0,12188.0)
Upper Right (11451.0, 0.0)
Lower Right (11451.0,12188.0)
Center ( 5725.5, 6094.0)
Am I missing something? I have GDAL_DATA set appropriately and am using
GDAL 2.1.1 on Windows.
I would like to either treat the .tif + .tif.aux.xml as a GeoTIFF or else
translate it to one.
Thanks very much,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170118/c4cb0613/attachment.html>
