[gdal-dev] Question about .aux.xml sidecar file handling...
Even Rouault
even.rouault at spatialys.com
Thu Jan 19 03:17:11 PST 2017
On mercredi 18 janvier 2017 06:55:49 CET Carl Godkin wrote:
> Hi,
> I have a geological map in a pair of files called USGS.tif and
> USGS.tif.aux.xml
> The XML seems to have ground control points (<SourceGCPs>) and a geographic
> coordinate system (<SpatialReference>)
GDAL .aux.xml files do no have <SourceGCPs> or <SpatialReference> elements, so it
looks like this .aux.xml file is a USGS specific one (yikes!)
The names understood by GDAL are <GCPList> and the SRS is stored as a Projection
attribute of <GCPList>
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170119/8ed76140/attachment.html>
