[gdal-dev] Shapefile with one feature and many incrementally-added vertices is huge
Even Rouault
even.rouault at spatialys.com
Thu Jan 19 23:49:22 PST 2017
On vendredi 20 janvier 2017 10:45:56 CET Nik Sands wrote:
> Thanks Guys,
> I appreciate the great responses, and particularly implementing an
> update for this edge case.
> Unfortunately, I'm stuck with GDAL 1.x for now (have yet to figure out
> how to get 2.x to build for iOS, but will take another look some
> time).
You should be able to apply the patch to 1.11 in a rather straightforward way.
> As for alternatives to Shapefiles, my preference is for
> SQLite/Spatialite, but I'm having other problems with that at present
> (haven't defined the problems well enough to post a query here yet).
> I will take a look at GeoPackage. I'm not familiar with this format.
> Cheers,
> Nik.
> ----- Original Message -----
> From: "Stefan Keller" <sfkeller at gmail.com>
> To:"Even Rouault" <even.rouault at spatialys.com>
> Cc:"gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Sent:Thu, 19 Jan 2017 15:31:07 +0100
> Subject:Re: [gdal-dev] Shapefile with one feature and many
> @Even: Great work!
> @Nik: I would avoid using Shapefile in the first place.
> IMHO there are other formats which hare better suited for this use
> case, like e.g. GeoPackage.
> :Stefan
> 2017-01-19 14:38 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> >> In that
> >> particular case the writer could realize that we are editing the
> last
> >> geometry, so it could safely overwrite in place, but this isn't
> >> implemented
> >> yet.
> > Well, that was rather simple to implement. So fixed per
> > https://trac.osgeo.org/gdal/ticket/6787
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170120/bf7fa89f/attachment-0001.html>
