[gdal-dev] Participating on gdal2tiles
Grégory Bataille
gregory.bataille at gmail.com
Fri Jan 20 01:53:36 PST 2017
yes indeed, that would be one of the things I'd like to try and do...
A few bug fix before though and then I'll see
Thanks
Gregory Bataille
On Fri, Jan 20, 2017 at 10:34 AM, Sean Gillies <sean at mapbox.com> wrote:
> Hi Grégory,
> On Fri, Jan 20, 2017 at 8:59 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On vendredi 20 janvier 2017 05:45:28 CET Grégory Bataille wrote:
>> > Hi everyone,
>> > I just subscribed to this list. Due to current interest, driven by my
>> > current job, I'd like to participate on gdal2tiles.
>> > However I'm not sure how to go about it and how active the development
>> > still is.
>> > I, for example, encountered an issue, that after investigation led me
>> there
>> > https://trac.osgeo.org/gdal/ticket/6057. It's a ticket with a proposed
>> > solution and code patch, but that has seen no activity in 18 months.
>> > Would you mind advising on the best way to contribute? Is the
>> > development/review process, on gdal2tiles still active and is it worth
>> > investing time on it?
>> Hi Grégory,
>> To be honest, I haven't processed gdal2tiles tickets for years as an
>> experiment to see how much time it would take for an existing or new
>> contributor to step up ;-)
>> I'd suggest you to submit pull requests on the github mirror so that the
>> Travis-CI tests are run on your patches. And I'd strongly encourage you to
>> write new tests in ../autotest/pyscripts/test_gdal2tiles.py for each
>> issue fixed.
>> Even
> If you want an example of how to speed things up with Python's
> multiprocessing module, check out https://github.com/mapbox/rio-
> mbtiles/blob/master/mbtiles/scripts/cli.py. I've found in rio-mbtiles
> that the small amount of inter-process communication overhead is worth it
> and multiprocessing is the only good way to achieve CPU intensive
> concurrency with Python.
> Yours,
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170120/d17ee1ac/attachment.html>
