[gdal-dev] GDAL 2.1.3 release candiate
Even Rouault even.rouault at spatialys.com
Sat Jan 21 12:04:08 PST 2017
On samedi 21 janvier 2017 11:31:30 CET Greg Troxel wrote:
> (I'm working on upgrading the pkgsrc entry from 2.0.3 to 2.1.2.  Surely
> from there 2.1.3 will be easy.  I don't yet have a coherent note about
> where I am on this, but wanted to post something quick.  Once I've done
> that I'll either test 2.1.3RC or move to 2.1.3 depending on where you
> are.  This is not a request to wait for me; I'm behind and that wouldn't
> be reasonable.)
> I couldn't find how to run tests (which I am assuming exist);
> there was not a test or check target.   I didn't find a README in th
> sources, and the wiki info which I did find pointed to by docs doesn't
> mention running tests.
> For 2.1.2 I had to add the following patch.
Committed. Thanks
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170121/9938f4f2/attachment.html>
