[gdal-dev] compile gdal 2.1.3 with HDF5 support on Debian Lennie
Andrew C Aitchison
andrew at aitchison.me.uk
Fri Jan 27 06:26:14 PST 2017
Rainer,
I'm not very familiar with Debian or apt-get, but does installing libhdf5
perhaps with something like
apt-get install -y --no-install-recommends libhdf5
help ?
If so, the "--no-install-recommends" may be making things harder for you.
Alternatively, the problem *might* be that the commented lines (##)
do not end with a backslash (/).
On Fri, 27 Jan 2017, Rainer M Krug wrote:
> Hi
> We am working on a docker image for spatial analysis using R (see
> https://github.com/rocker-org/rocker/issues/213 for the discussion) and
> I am struggling to get gdal compiled with HDF5 support.
> I install the following dependencies:
> --8<---------------cut here---------------start------------->8---
> apt-get install -y --no-install-recommends \
> libproj-dev \
> libgeos-dev \
> ## hdf4
> libhdf4-alt-dev \
> ## hdf5
> libhdf5-dev \
> libhdf5-serial-dev \
> zlib1g-dev \
> ## sqlite
> libsqlite3-dev \
> ## freexl
> libfreexl.dev \
> ## odbc
> unixodbc-dev \
> ## diverse
> libexpat1-dev \
> libxerces-c-dev \
> libnetcdf-dev \
> libudunits2-dev \
> ## KML
> libkml-dev
> --8<---------------cut here---------------end--------------->8---
> and use the following configure options
> ./configure \
> --with-geotiff \
> --with-sqlite3 \
> --with-freexl \
> --with-spatialite \
> --with-geos \
> --with-hdf4 \
> --with-hdf5 \
> --with-libjson-c \
> --with-netcdf \
> --with-odbc \
> --with-curl \
> --without-grass \
> --without-libgrass
> But I get the following message in the configure output
> | checking for H5Fopen in -lhdf5... no
> which than results in
> | HDF5 support: no
> Any ideas what I am missing?
> Thanks,
> Rainer
> Rainer M. Krug
> email: Rainer<at>krugs<dot>de
> PGP: 0x0F52F982
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
