[gdal-dev] compile gdal 2.1.3 with HDF5 support on Debian Lennie
Rainer M Krug Rainer at krugs.de
Fri Jan 27 06:37:58 PST 2017
Even Rouault <even.rouault at spatialys.com> writes:
> On vendredi 27 janvier 2017 14:28:21 CET Rainer M Krug wrote:
>> Hi
>> We am working on a docker image for spatial analysis using R (see
>> https://github.com/rocker-org/rocker/issues/213 for the discussion) and
>> I am struggling to get gdal compiled with HDF5 support.
>> Any ideas what I am missing?
> Rainer,
> Try ./configure --with-hdf5=/usr/lib/x86_64-linux-gnu/hdf5/serial
Perfect - that works. And I could even remove libhdf5-serial-dev and
zlib1g-dev as dependencies.
> In trunk HDF5 detection has been improved so that plain --with-hdf5 works, but not in 2.1 branch.
OK. Thanks a lot,
Rainer
> Even
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170127/e1ba36d4/attachment.sig>
