[gdal-dev] Zip files and VISFileFromMemBuffer()
Sean Gillies
sean at mapbox.com
Tue Jan 31 15:35:31 PST 2017
Thanks for confirming that I was on the right trail, Even! I got it figured
out: I was naively trying to open the /vsizip/vsimem/ file in update mode.
In case you're interested, my new Python usage is like this:
with open(path_zip_file, 'rb') as f:
with MemoryFile(f) as memfile:
with memfile.open('white-gemini-iv.vrt') as dataset:
assert dataset.count == 3
https://github.com/mapbox/rasterio/pull/972/files#diff-d3388b510bd97235e4741b8417cc41e9R148
On Tue, Jan 31, 2017 at 5:42 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 31 janvier 2017 17:33:23 CET Sean Gillies wrote:
> > Hey all,
> > The tests in
> > https://svn.osgeo.org/gdal/branches/1.9/autotest/gcore/vsizip.py show
> how
> > to create a zip archive in memory and create directories and files within
> > it. I'm looking for a shortcut.
> > Given a sequence of bytes representing an existing zip file that
> contains a
> > TIFF and a VRT (referencing the TIFF), is it possible to make a VSI file
> > from this buffer (using VISFileFromMemBuffer()) and then access the VRT
> > using a path like /vsizip/vsimem/archive.zip/example.vrt protocol?
> Hi Sean,
> That sounds like you tested it and something went wrong ? Perhaps check
> the path to the source in the VRT and the value of the relativeToVRT
> attribute.
> Your above strategy does work for me:
> $ gdal_translate byte.tif byte.vrt -of VRT
> Input file size is 20, 20
> $ zip byte.tif.zip byte.tif byte.vrt
> adding: byte.tif (deflated 96%)
> adding: byte.vrt (deflated 53%)
> $ python
> >>> from osgeo import gdal
> >>> data = open('byte.tif.zip', 'rb').read()
> >>> gdal.FileFromMemBuffer('/vsimem/archive.zip', data)
> >>> ds = gdal.Open('/vsizip/vsimem/archive.zip/byte.vrt')
> >>> ds.GetRasterBand(1).Checksum()
> 4672
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170201/6aa64007/attachment.html>
