[gdal-dev] How to convert a local GeoTIFF to a tile set with minimal WMTSCapabilities.xml?
Stefan Keller
sfkeller at gmail.com
Fri Jul 21 03:42:04 PDT 2017
Update: I found not much so far regarding creation of WMTSCapabilities.xml...
There exists this free web tool http://wmts.maptiler.com/ which can
generate an XML given an URL.
Then it seems that UMN MapServer can also generate this XML given a
WMTS is configured with it's Mapfile.
That's it!
I'm still open for feedback on this tedious task which for sure could
be automated.
IMHO it would be a great extension especially to gdal2tiles.
:Stefan
2017-06-07 17:36 GMT+02:00 Stefan Keller <sfkeller at gmail.com>:
> Sorry for this question since I know GDAL. But it seems I'm missing
> something here:
> I'd like to do the following:
> A. Given a local GeoTIFF, create WMTS compatible tile set (of single
> zoom level 18 or a range)
> % python gdal2tiles.py -z 18 infile.tif outdir
> B. Then I'd like to test this locally
> % gdalinfo WMTSCapabilities.xml
> C. or - if needed - I copy WMTSCapabilities.xml to a web space (say
> https://www.myweb.org/wmts/1.0.0/WMTSCapabilities.xml) with the
> unpacked tile set - and test it there.
> Step A works but produces no WMTSCapabilities.xml (stub), only
> tilemapresource.xml which obviously is not same as
> 1. How can I generate such a WMTSCapabilities.xml?
> 2. What is the "minimal viable" XML, given I want/have to create
> WMTSCapabilities.xml by hand?
> :Stefan
