[gdal-dev] Problem with polygon and gdal.RasterizeLayer causing endless cpu usage
Casper Børgesen caboe at sdfe.dk
Fri Jun 2 06:55:12 PDT 2017
Hi Even
Thank you for the fast bug fix, and for pointing out what the problem was. I look forward to test the fix when the current code reaches OSGeo4W.
Regards, Casper
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: 2. juni 2017 14:09
To: gdal-dev at lists.osgeo.org
Cc: Casper Børgesen
Subject: Re: [gdal-dev] Problem with polygon and gdal.RasterizeLayer causing endless cpu usage
Casper,
actually this was known as https://trac.osgeo.org/gdal/ticket/5580
I've just fixed it (at least for your case and the one reported in the ticket)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170602/a5b91772/attachment.html>
