[gdal-dev] gdalenhance command issue with stddev option
naresh
naresh919 at gmail.com
Mon Jun 5 23:52:22 PDT 2017
Dear Rahkonen,
Thanks for the quick response. However with gdalenhace -help showing the
-stddev option. Please find the attache screenshot.
[image: Inline image 1]
Is there any other mechanism/tool is available for enhancing the images
with stddev option.
Thanks&Regards,
Naresh
On Tue, Jun 6, 2017 at 10:48 AM, jratike80 [via OSGeo.org] <
ml+s1560n5323140h33 at n6.nabble.com> wrote:
> naresh wrote
> Dear All,
> I have configured GDAL2.1.0 in windows 64 bit machine. I am using
> following command
> gdalenhance -of JPEG -stddev 2.0 E:\first.jpg E:\first_enhance.jpg
> got the following error
> option -stddev incomplete, or not recognised
> Please help me how to use gdalenhance command with option stddev
> Thanks&Regards,
> Naresh
> Hi,
> By http://lists.maptools.org/pipermail/fwtools/2008-February/001153.html the
> tool was 9 years ago "essentially an abandoned prototype".
> -Jukka Rahkonen-
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/gdalenhance-command-issue-with-stddev-
> option-tp5323137p5323140.html
> To unsubscribe from gdalenhance command issue with stddev option, click
> here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5323137&code=bmFyZXNoOTE5QGdtYWlsLmNvbXw1MzIzMTM3fC0xMDc3NTYzNDE5>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
image.png (48K) <http://osgeo-org.1560.x6.nabble.com/attachment/5323152/0/image.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdalenhance-command-issue-with-stddev-option-tp5323137p5323152.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170605/7a463ef7/attachment.html>
