[gdal-dev] .exe extension missing for gdal-2.2.0 binaries
Even Rouault
even.rouault at spatialys.com
Fri Jun 9 01:30:59 PDT 2017
On vendredi 9 juin 2017 12:16:17 CEST Velagandula, Sravan Kumar wrote:
> Hello,
> I am trying to build gdal-2.2.0 from source on windows 7 64 bit using
> msys2 environment. gcc is 4.8.3.
> This is the source I am using:
> http://download.osgeo.org/gdal/2.2.0/gdal-2.2.0.tar.gz
> The binaries produced do not have the .exe extension. But building the
> gdal-2.0.3 produces the binaries
> with the .exe extension. I am wondering if anyone else has across this
> issue and if so if they were able
> to find a resolution. I appreciate your help.
Sravan,
I don't think this aspect of the project has changed in years. Did you use the same msys/
mingw toolchain when compiling GDAL 2.0 and GDAL 2.2 ? I suspect not
In configure.ac, the relevant snippet is :
dnl ---------------------------------------------------------------------------
dnl Check whether we need to add specific suffix for executables (.EXE when
dnl building for Windows). This test should work for the case of
dnl cross-compilation too.
case "${host_os}" in
cygwin* | mingw32* | pw32*)
EXE_EXT=.exe
SO_EXT=dll
EXE_EXT=
esac
I suspect that your toolchain is identified a bit differently.
Could you open "configure" in a text editor and add the following lines at the end of it :
echo "-------------------------"
echo "Host OS: '${host_os}'"
Then run configure again and report the value displayed
For example with the x86_64-w64-mingw32 cross-compilation toolchain (host: Linux), I get
the following, which matches the above expressions
Host OS: 'mingw32'
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170609/459394d3/attachment.html>
