[gdal-dev] .exe extension missing for gdal-2.2.0 binaries
Even Rouault
even.rouault at spatialys.com
Fri Jun 9 03:10:25 PDT 2017
On vendredi 9 juin 2017 15:31:12 CEST Velagandula, Sravan Kumar wrote:
> Hello Even,
> I see that the value of ${host_os} is "mingw64" for gdal-2.20 and
> "mingw32" for gdal-2.0
OK, so with a different toolchain between both builds ?
Anyway, should be now fixed per https://trac.osgeo.org/gdal/ticket/6919 that changes the
mingw32* pattern to mingw* to catch both cases.
Or you can just edit GDALmake.opt after ./configure , look for the
EXE =
line and modify it as
EXE = .exe
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170609/ae5bd968/attachment.html>
