[gdal-dev] gdal_calc not ignoring NoData values?
Spencer Gardner
spencergardner at gmail.com
Mon Jun 12 07:40:54 PDT 2017
I have two integer rasters, A and B, with the same dimensions and cell
sizes. I want to compare each cell in A with each cell in B and keep the
maximum value. In cases where both have nodata, I want the result to be
nodata. In cases where one is nodata, I want the result to be the integer
value of the one with data.
Raster A Raster B
| 1 | 1 | | 3 | 1 |
| 1 |nodata| |nodata| 3 |
|nodata| 1 | |nodata|nodata|
|nodata| 4 | |nodata| 1 |
Desired result
| 3 | 1 |
| 1 | 3 |
|nodata| 1 |
|nodata| 4 |
've tried combining them in many different ways using gdal_calc but somehow
I can't seem to get the answer I'm looking for. My first instinct was to
use numpy.fmax since the documentation states that the NaN value is
ignored. But this calculation
--calc "numpy.fmax(A,B)"
only gives me the results I want in cells where both datasets have a value.
A nodata in either results in nodata in the result:
numpy.fmax result
| 3 | 1 |
|nodata|nodata|
|nodata|nodata|
|nodata| 4 |
Perhaps I'm confused about how nodata translates to NaN in numpy? What is a
straightforward way to accomplish this with gdal_calc?
Thanks for any help,
Spencer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170612/67f484f0/attachment.html>
