[gdal-dev] Question on creating geotiff from tif based on tfw/tab and EPSG code
Niels.vonFestenberg-Packisch.ext at rohde-schwarz.com
Mon Jun 12 08:22:58 PDT 2017
Hello,
I would like to add geotiff meta data to an existing tif file.
The meta data is known as tfw/tab files and as EPSG code. I was trying
hard to have this done with fwtools and geotifcp, but I couldn't create a
proper meta data file based on the EPSG code (even though the proj4 is
available). As I haven't got a working sample file with the desired EPSG
code, I wonder if there is some non-manual method to create one based on
one of the strings given here: http://spatialreference.org/ref/epsg/31468/
Is this feasible at all? Or how would a GDAL expert do this?
Any hint would be welcome!
Thank you very much in advance
Niels
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170612/2962ce4e/attachment.html>
