[gdal-dev] r 39092: vsigzip filesize check
Kurt Schwehr
schwehr at gmail.com
Fri Jun 16 05:40:53 PDT 2017
Even,
With https://trac.osgeo.org/gdal/changeset/39092, can you explain the this
check?
uncompressed_pos - startOff > m_compressed_size
That looks to be comparing the number of bytes compressed vrs
uncompressed. How is this checking that the filesize changed? Something
seems wrong or there needs to be a comment somewhere because this doesn't
seem correct.
Thanks,
-kurt
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170616/b560c0f7/attachment.html>
