[gdal-dev] gdal 8-bit signed int support unavailable?
Even Rouault
even.rouault at spatialys.com
Mon Jun 19 03:52:17 PDT 2017
On lundi 19 juin 2017 03:44:10 CEST Kenlo Nasahara wrote:
> Even, thanks a lot. It was a surprise for me that GDAL does not support
> 8-bit signed int. It may be better not to use it with GDAL. Kenlo Nasahara
If you've got the choice, use Int16 datatype instead.
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdal-8-bit-signed-int-support-> unavailable-tp5324647p5324652.html Sent from the GDAL - Dev mailing list
> archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170619/5d7b9a64/attachment.html>
