[gdal-dev] Cannot open S3 files after upload
Matt Hanson
matt.a.hanson at gmail.com
Wed Jun 21 08:47:49 PDT 2017
Thanks Even,
Disabling reading the directory is another work around for my use case as
well:
(GDAL_DISABLE_READDIR_ON_OPEN=TRUE)
On Wed, Jun 21, 2017 at 5:02 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Matt,
> > My actual problem is a bit more specific then being unable to open S3
> files
> > after upload. The actual problem is that within the same Python session,
> I
> > can open a file off S3 with the vsis3 driver, but then if I upload a new
> > file that previously did not exist (using boto3), gdal does not see it
> as a
> > valid file.
> Yes I'm aware of that issue. There's indeed metadata (file size & date,
> directory listing) and data (chunks of files) cached by /vsicurl/ and
> related file systems like /vsis3/ . /vsicurl/ was designed at a time where
> web resources didn't change that much and it was unlikely during a same
> GDAL session to see changes, but with cloud offerings, this is no longer
> the case.
> A few weeks ago I've added in trunk a CPL_VSIL_CURL_NON_CACHED config
> option that can be set to disable caching on a file or set of files.
> See https://trac.osgeo.org/gdal/wiki/ConfigOptions#CPL_VSIL_
> CURL_NON_CACHED
> So in your example, if you set
> CPL_VSIL_CURL_NON_CACHED=/vsis3/put_here_the_bucket_name , that will work.
> I've also just added per https://trac.osgeo.org/gdal/ticket/6937 a new
> function VSICurlClearCache() function (bound to SWIG as
> gdal.VSICurlClearCache()). So if you add gdal.VSICurlClearCache() just
> after the s3.meta.client.upload_file() call, that will work too.
> Both mechanisms are complementary.
> CPL_VSIL_CURL_NON_CACHED is useful in scenarios where you don't know when
> the server content can change (some other processes or machines do that
> behind your back). Its advantage is that it doesn't require modification of
> code (it was designed for MapServer use case typically). The drawback of it
> is that you loose all caching when a same file is opened, close, opened,
> closed, ... several times during the process.
> VSICurlClearCache() will give you more control if you master when uploads
> happen.
> I've also backported VSICurlClearCache() to 2.2 branch.
> As far as VSI_CACHE=TRUE is concerned, its scope of caching is restricted
> to a same VSI file handle instance. Can be useful if the global 16 MB
> vsicurl cache isn't big enough for very large files.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170621/9b46e2e2/attachment.html>
