[gdal-dev] gdaladdo without explicit factors specified
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Jun 28 08:08:11 PDT 2017
Even Rouault-2 wrote
> Hi,
> I'm pretty sure this must have annoyed a lot of people. When you run
> gdaladdo, you need to
> specify the appropriate overview levels. Generally you use power-of-two
> factors, but the
> question is then: what is the last relevant factor given the dimension of
> my file size ?
> Thoughts ?
Excellent idea especially because it works in scripts also with variable
sized images. My second thought is that is there any living soul in the
World who can memorize "--config COMPRESS_OVERVIEW JPEG --config
PHOTOMETRIC_OVERVIEW YCBCR --config INTERLEAVE_OVERVIEW PIXEL" without going
to http://www.gdal.org/gdaladdo.html or by re-using their old scripts?
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdaladdo-without-explicit-factors-specified-tp5325832p5325875.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
