[gdal-dev] Gdal_retile - overviews - incremental updates
Anna-Lena.Hock at bkg.bund.de
Fri Jun 30 04:52:26 PDT 2017
Hello,
currently I am building overviews with gdal_retile for a bunch of tiled rasters - the overviews are stored in geotiff for each level in a separate folder 1, 2, 3, 4.
I am quite happy with the performance of the format on geoserver, but I think there is a problem with updates. Usually just some rasters get an update - the rest remains the same. So I want to recalculate only some rasters and all the overviews of those.
I couldn't find a way to recalculate only a part of a the gdal_retile output - it's always adding new geotiffs instead of overwriting the existing ones. I thought maybe gdalddo is an alternative to gdal_retile for the updates, but as far as I see it's not possible to create a pyramid with external tif files (not ovr).
So, my question is: Is there a possibility to recalculate a part of a pyramid created with gdal_retile?
Thanks!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170630/a4f51db3/attachment.html>
